RE: Help removing CA from plastic canopy!!
Guys, the best way is to use glow fuel. Soak a paper towel with fresh glow fuel and let it soak for 15 minutes or so. The higher the nitro content the faster it will work. Glow fuel will not harm the canopy at all, monokote is safe to use it on also. You will wipe the glue drop off and never have known that it was there. Nitro disolves CA. Loctite makes a product called XNMS clean up solvent, it is 99% nitro. It is used to clean loctite off from threads and the such. Try this, it will surprise you.
