RCU Forums - View Single Post - Co_Pilot
Thread: Co_Pilot
Old 11-03-2004 | 07:53 AM
flyerdarren's Avatar
flyerdarren
Default RE: Co_Pilot
II noticed you mentioned mounting a co-pilot under the fuselage. I wouldn't recommend putting it under there, The heat from your exhaust can confuse the sensor. I had one on a cloud dancer mounted under the wing, the co-pilot kept rolling the plane away from the exhaust. I fought to hold on, but to no avail. Definitely set it up so you can turn it on or off during flight, or better yet, set it up on a proportional channel so you can adjust the sensitivity while in flight. Good Luck.
