RCU Forums - View Single Post - 3D Foamy
Thread: 3D Foamy
Old 11-03-2004 | 09:26 AM
  #43
typicalaimster's Avatar
typicalaimster
Default RE: 3D Foamy
ORIGINAL: craigman
Ok guys,, i'm think'n of ordering a foamy from 3D Foamy, and was wondering which one you guys recomment? Which ones do you have, and fly?
Let me know your thoughts!
I have the Edge 540 and the Citabria... I found the Citabria something I'd use as a trainer. The Edge I've been using to perform stupid foamy tricks. I haven't REALLY been doing 3D hovering. Just mostly flying map of the earth and between trees in the wooded area behind our house. The Edge has REALLY taken a beating. I have hit or put it up in several trees. The foam has cracked, but after a quick zap of CA it's back up in the air.
I setup all hinges with the CA hinges. I didn't put the center plywood piece in for the elevator. I used 4 CA hinges instead. Just simply cut a full sized hinge in half, and mulah!
I'm looking forward to mounting a Black Widow Cam in one of these planes. I'm even thinking about ordering the F-18 so I can get more of a Jet feel to things!
