RE: NT-16 Engine
madmark,
You want to make sure that your chassis, center shaft, rear shock tower, or rear brace is not bent. IF one of them are, it is possible that your pinion gear that goes to the rear differential is not meshing correctly with the differential main gear. Check it out. When you roll the car forward is it moving smoothly or making noise?
Regards,
CEN RACING
