RCU Forums - View Single Post - Which engine for Exta 300 special
Old 11-03-2004 | 07:46 PM
Easy does it
Banned
Default RE: Which engine for Exta 300 special
I am sorry it took so long to reply, finished everything tonight after work except final items loctite etc. I used pull pull on the rudder I have two li-ion batts for the receiver 2800 mah on the tray (yes overkill ) a 2000 mah li-ion in front of the fuel tank for ignition the module is mounted on the firewall I have a 3W 22/10 prop and tru turn spinner. Believe it or not my wife helped me just 10 minutes ago it balanced perfectly at 2.5 inches back from leading edge as per spec, I like nose heavy for first few flights.
I used JR 8611 servos all round and the pull pull turnbuckles and 1 inch engine standoffs from swbmfg.com also their 3 inch rudder arm. Now if only I can do justice to this beautifull plane (and I mean that Wild Hare has a great product,there is no way I could have built it any better) with my flying skills It will be a great winter flying season hear in sunny FLA.
Any thing else I can help you with let me know
