RCU Forums - View Single Post - GP Venus 40 Engine Thrust
Old 11-03-2004 | 11:32 PM
dlwood
Default RE: GP Venus 40 Engine Thrust
The thrust is built into the firewall. To verify you can drill a flat plate
using a drill press to insure it is at right angles. Insert a 12 to 18 inch rod into the plate(snug fit please). Hold the plate against the fire wall with the rod passing into the fuselage. any angle
built into the fire wall is readily apparent.
