RE: epoxy and blind nuts
I've also successfully just put a coat of oil on the bolts and, after the epoxy has partially set up, unscrew the bolts. If one give you a bit of trouble, just heat the bolt with a soldering gun and it will come right out. On occasion, I've even left the bolts in until full cure (overnight) and had no problem removing the pre oiled bolts.
