RE: Rookie Servo Question!
Thanks Gord,
To make sure I got it right, the brown wire matches up with black, the reds are in the middle and orange lines up with white. Sounds simple enough. My TM build has been a slow process due to lack of free time and waiting for the cash to buy the electronic gear. I already did the landing gear mod. Copied it from a TM400 build thread. Probably the same one you saw the picture. How did you route your rx antenna through the fuselage? Or did you do it before you glued the halves together? Any special exit point? Hope to be ready for the maiden next weekend.
Thanks again, Rick
