RCU Forums - View Single Post - Black Horse Matrix CG
Old 11-04-2004 | 09:04 PM
forestroke's Avatar
forestroke
Default RE: Black Horse Matrix CG
smartmove - yes... i have to say that upon initial inspection of the matrix, i was also very impressed. it is a beautiful arf.
i have encountered another problem, though... for those of you that don't have the engine mount holes drilled through the firewall already and need to use the template in the manual or want to change the mounting to inverted or sidewinder, PLEASE BEWARE! the template in the manual is smaller than the actual plane. that mean's when you measure and drill, the holes will come out too close together. i had to drill out some of the engine mounts.
tIANci - i'm no longer in Hong Kong and even then it's so hard to get hold of Saito let alone their parts!
