RCU Forums - View Single Post - FS Engine compression?
Old 11-04-2004 | 09:34 PM
Live Wire's Avatar
Live Wire
Default RE: FS Engine compression?
The intake valve is the culprit. Carbon build up in the seat or bent valve. If you lap the valve make sure you clean real well with soap and water. Comet cleaner or Borax can be used as a lapping compound.
