RCU Forums - View Single Post - Anodizing Aluminum --- Instructions for all to use
Old 11-04-2004 | 10:48 PM
mr-rccrazy's Avatar
mr-rccrazy
Default RE: Anodizing Aluminum --- Instructions for all to use
I just thought that people might want some simple and cheap instructions on how to anodize, and plus,
note that just using Sulphuric acid to Anodize without it containing high levels of Aluminium will take longer and give a poor result and uneven coating of the parts ....
uhh, what do you mean? The actual anodizing you cannot see, keep in mind the coloring process is done separate from the actual anodizing. So, if it is not a perfectly "even" anodizing, you will not see it. I just wanted anodizing for cool looks, not as much as making the aluminum harder.
