RCU Forums - View Single Post - Electronic Ignition Theory
Old 11-06-2004 | 07:28 AM
Orvie6
Default RE: Electronic Ignition Theory
Newbie here,
I have been reading about the differences in the electronic ignitions, mainly the one by Jerry Howell and the one manufactured by CH. I knkow that the Howell one is a basic Kettering design and the CH is a CDI unit. My question is: Will the Syncro Spark module for the CH work with the Howell ignition? From what I understand, it plugs in between the Hall effect sensor and the rest of the circuit. I plan on using the Howell system on a 100cc Tecumseh snowblower engine. It is a 2 cycle piston port engine and stripped down (minus flywheel and mag) it weighs in at about 7 Lbs. Thanks for all the info.
