RCU Forums - View Single Post - Is wing loading relative across sizes?
Old 11-06-2004 | 04:14 PM
Ben Lanterman's Avatar
Ben Lanterman
Default RE: Is wing loading relative across sizes?
Gordon,
It always assumed that an airplane size (scale, whatever) is known when discussing wing loading. It is like discussing sex without saying if the object of discussion was a man or woman.
It is incorrect to think of the number as a "volume" as indeed the volume inside of an airplane is quite independent of the wing area.
The response of a wing to air has everything to do with Reynolds number - if it doesn't then all of the work I have done over a lifetime matching wind tunnel Reynolds numbers to data goodness has been pretty well wasted!!
I agree with Dick that in terms of model work ounces per sq ft is a good rule of thumb to use but again it does need a airplane size to go with it. Terms like .40 or .60 powered, hand launched gliders, parkfliers, pattern, scale, giant scale, etc. all immediately bring to the mind a relative size and wing loading that works nicely.
