RCU Forums - View Single Post - differences in timing between points system and CH ign?
Old 11-06-2004 | 08:07 PM
captinjohn
Default RE: differences in timing between points system and CH ign?
Side-7 I would say if you move the pick-up, say 90 degrees...then to keep the same timing...rotate the flywheel on the shaft the same 90 degrees. Should work I would think? Capt,n
