RCU Forums - View Single Post - differences in timing between points system and CH ign?
Old 11-07-2004 | 01:04 AM
mikenlapaz
Default RE: differences in timing between points system and CH ign?
av8tor1977 you are correct. I meant to correct post when I realized mistake and got sidetracked.
Should read 'sensor at maximum CW position, and the flywheel at 32 BTDC' Movement of sensor CCW reduces the timing advance.
Rotation is std CCW
