RE: Need help IDing this engine...
Any muffler recommendations? RCIGN1 says this is a A&M/Sachs... Will check the crank as you said. Thanks. Got it for aprox. 200 USD supposedly with low time on it. If not a good engine I have the option and return it to the owner. Will try and start it after checking the crank to see if it is a Sachs. Is it any good, it was going on a Lanier 1/3 Extra 300... Will this be right, should I return it?
Homero
