RCU Forums - View Single Post - Composite ARF Impact
Old 11-07-2004 | 07:07 AM
  #208
David Gibbs's Avatar
David Gibbs
Default RE: Impact
Hi Guys,
Down here in Oz and 3/4 way through building. Have used Gator adjusters and DEPS for elevators. Tray area looks like attached.
Wing adjusters are just in front of the holes for the original incidence pin -- the back of the ply diamonds (or squares at an angle) just cover the original holes.
All other building issues as per this thread (oval wing tubes, oversize stab tube, cut out too much for engine area -- and I hate sanding carbon -- I put the micrometer on the stab tubes -- ID of retainer 10.01 mm, OD of tube 10.12mm).
But value for money I think it is great. About the same amount of work as the Hydeaway (except I went for the pre-painted Impact) but lots less money here. I also have an OXAI Impression -- it is certainly more work than that. Thanks for all the great input on trimming and C of G. Mine is set initially at 0 degrees stab and motor, +0.25 wings. Using OS140 RX and standard pipe. All fits neatly.
