RCU Forums - View Single Post - differences in timing between points system and CH ign?
Old 11-07-2004 | 11:56 AM
av8tor1977's Avatar
av8tor1977
Default RE: differences in timing between points system and CH ign?
Well, here's a link, a really good one that explains it better than I can: www.foxvalleykart.com/timing1.html
In your case, I would use a timing light to make a mark on the case (and flywheel) to indicate the present timing. You could then experiment from there. If you want to know the timing in degrees, just use a degree wheel to check what degrees your mark actually indicates BTDC.
Good luck,
AV8TOR
