RE: advice on using Exponential
Try flying the Magic with NO expo. If you have no problems then keep it that way. If it seems a little touchy, add some. Some planes in all honesty don't need it. The throws should be set at the manufacturers recommended settings to start with. Once you get comfortable with the Magic, you will have a better idea where to go with the setup.
Jim C
