RE: Vectorflight: To good to be true?
Rcfury, pushrods should already be installed in the sleeves. It will be a piece of cake. For my first Vector I too looked for them in the box before realizing they were already done. You're right the instructions are short and condensed, but read it all, they explain almost everything you will need to know to put her together. The spacer or template for setting wing joiners should be done carefully, definately do a dry run before epoxy!
Kolarshooter, congratulations on the maiden! [8D]
