RCU Forums - View Single Post - Avistar conversion
Old 11-08-2004 | 09:39 AM
StephenT
Default RE: Avistar conversion
Nova
Read the whole thread first!!!!
Follow the setup above or the brushless system I suggest earlier on your thread and you will get good results. Level flight, loops, rolls and inverted are possible Since a Superstar has a flat bottom wing, you should have better flight stability. Don't cheap out on Radio Shack or Epic 3000 Batteries. They will work on the Brushless system(32 Amps) but the Brushed Endoplasma (40 Amps)Motor pulls too many Amps for the low priced power source. You need to go with GP3300 Nimh(8 min) or GP1900SCR(4 min) rated at 40+ Amps. Clean the brushes and commuter often. If I had it too do over again I would have gone brushless first. Read the thread. Don't cheap out!!!
