For those that are not familiar with this plane, it is made by an Italian company called ARC in Cremona, Italy. It is made entirely out of ABS plastic. This is my second ARF, the first was (is) the SIG LT-40.
I have Saito .56 in it, 5 HS-425 servos with flapperon and spoileron programmed. Havn't flown it yet, but I am very anxious to try. The building construction was pretty uneventful, except for the time when I had to install the engine in the
very tight cowl.
However, I think that the engineering on the plane is pretty remarkable, and I hope that it flies as well as it is engineered.
