ORIGINAL: cwrr5
Yes, as he stated above, red anti-collision light, left wing tip. blue/green anticollision light right wingtip. white(yellowish) on beavertail(actually two seperate lights, arranged like: sideways 8). Landing light in each main gear door, Landing light in the forward edge of each wingtip, retractable landing/taxi light inboard of external fuel tanks. bottom strobe just aft of nose gear, can be switched either red or white. Top strobe(depending on model) is halfway between wing and vertical stab on top of fuselage, also can be switched either red or white. Some models have their top strobe on top of the vertical stab, again either red or white. Also, fuselage light on both sides just forward of the props, pointed at the wingtips(inspection lights). Hope this helps... If I get a chance (I work on these-they keep us busy
), I'll post some pics.
