RE: Impact
David,
A question for you? In your picture below how do you assume the wing tube is dead level?? Do you do it by eye? Do you measure from the floor up to the tube? If so, how do you know the floor is dead flat? What are your tolerances? If one end of the tube is 1mm higher than the other do you accept that??
Mark
