Unless you flexed your nacel which I doubt, I suspect you had something hit and pass through the prop which struck the fuse. As you pointed out you do have adequate clearance.
but then I did paint the red prop arc warning lines on mine.
Jim
You are right,, there is something special when you push the power up and hear 4 engines spool up for take off.
