RCU Forums - View Single Post - Wrong engine??
Old 11-08-2004 | 08:28 PM
RhyanO's Avatar
RhyanO
Default RE: Wrong engine??
Id say you have choosen a VERY good engine for this airplane.
Typically a 70 size 4 stroke is the the same power-wise as say a 40-46 size 2 stroke.
The huge advantage of a 4 stroke is that you are able to turn a larger prop. which makes the engine more efficient. ALso you will be able to run longer on a tank of fuel.
Ryan
