RE: Homey 30 hot rod + new smoke pump...
Idle: Cheap tricks 101
Just scribe the timing sensor bracket so you can return it to "correct" timing, then rotate the bracket about 20 deg CCW. See it the idle is improved enough for you to spend $$ on a Syncro Spark unit.
