RE: Engine dies at full throttle
mdavis223> Like you said, idle speed is constant but your engine cuts out when the throttle is fully opened . That simply means that your engine is running too lean. It doesn't get enough fuel (either on a high end or a low end). Try to open the high speed needle valve. If it still flames out, open the low end screw counter clockwise. If it doesn't work, there must be any leaks somewhere. Fuel Leak or air leak also makes the engine run lean. Anyhow, make sure that both needle valve and carburator are clean.
