RE: 100cc Tecumseh engine
Actualy you should have a 98cc engine. The Walbro WGA-3 carb will bolt up but needs a crank case pulse fitting tapped into the engine case and run to the carb. Yes I have one. I also have the 138cc and 49cc Tecumseh's as well. There is more info in the "Conversions" side.
