RE: My first build... she's done!!
Don't worry about orientation. This plane does not have a massive roll rate, it tends to fly level, and the high-wing and fin make the orientation easy. You'll find it easy to get right. (it flies awkward inverted as well.... if you are inverted and can't tell with this plane then you have bigger problems .... like no gravity....
gus
