RCU Forums - View Single Post - VectorFlight Rec. Engine Increase?
Old 11-09-2004 | 04:30 PM
ez2bgman's Avatar
ez2bgman
Default RE: VectorFlight Rec. Engine Increase?
Here's a reply I received from VF concerning engine selection:
"Thank you for your message. A 1.08 is not recommended as it may put too much stress on the airframe. A 91 2 stroke is the largest we recommend. A 90 4 stroke is also very popular, but many customers use a Saito 100 or YS 110 or Saito 120, all 4 strokes. A 91 2 stroke will provide excellent speed and vertical authority."
Best regards,
C/S
VF
I have a VF Edge 540 on order and plan on either a YS 1.10FZ or a Saito 1.00 as engine selection. The YS 1.10 would be a perfect match for the Edge. As much as I would like to put the YS in my Edge, I am leaning more toward the Saito 1.00. I figure that the extra money I would spend on the YS could be used for other modifications, as needed.
Another flyer by the name of Primodus has the Edge with a Saito 1.20. Check out this thread:
http://www.rcuniverse.com/forum/m_22...tm.htm#2215282
Good luck.
