RCU Forums - View Single Post - Onboard glow problem?
Old 11-10-2004 | 04:26 PM
higheronnitro
Default RE: Onboard glow problem?
You could be loosing to much voltage through the wiring and switch. Try larger / shorter cables and a double pole switch with the contacts paralleled together. The current drawn by a plug can be considerable which means any resistance between the battery and plug causes significant voltage drop. BR Steve
