thanks cafeenman,
i don't know it i understood it right.
after you've glued the sheets together you lay
them out on the wing and use "masking tape" to hold them
in position? that must be some strong masking tape to stick
to the skinny ribs!
I have great planes pro wood glue ( aliphatic resin)
will this work?
the top flight contender's destruction book has a "hot tip" on wing sheeting.
they say to cut a 3/32 x 3/4 x 24 from the 3/32 x 3" x 24
stock and glue to the same to make one 3/32 x 3-3/4 x 24 by taping them together, apply thin
ca sparingly, wipe off excess, repeat on the other side
and sand flat
before sheeting.
why couldn't they supply a 3/32 x 3-3/4 x 24 in the first place?
