RCU Forums - View Single Post - seagull laser 200
Old 11-10-2004 | 10:03 PM
Harc
Default RE: seagull laser 200
Rendegade - As I have said many times - You can't believe what you read. Horizon Hobbie's ad in Model Airplane News says:
Wingspan 69.25" Weight 10 - 11 Lb Engine 90 - 120 2 Stroke 1.20 - 1.50 4 stroke
Assembly Manual says:
Wingspan 68.75" Weight 9.02 - 11 Lb Engine sizes - as above Length 63.4"
So take your choice. My planes' wingspan is 69 3/16". Didn't measure the length. Appears to be a well built plane. The way I fly, it should stay glued together unless I develop a case of bad thumbs and smoke it in. I have been noted for doing that.
You can check it out at www.horizonhobby.com
The weight I said mine was could be off considerably. I use an old Kitchen scale that the wife discarded years ago. All it does is give my an approximation. Close enough for me.
Problem I was having with the trim turned out to be a faulty receiver. Don't know how many thumps its taken in its life. That has now been corrected. Like Bob Zaar, waiting for decent weather. 8 PM here in Denver, CO and snowing.
Anything else I can answer or help with, give a yell.
Harc
