RCU Forums - View Single Post - Sig Rascal 110 ARF
Old 11-11-2004 | 10:33 AM
Dewey2
My Feedback: (24)
Default RE: Sig Rascal 110 ARF
i just said the power didn't break the rib. show me the thread. what prop did you use. flying won't break a rib. one set of wings had a cracked rib when i got them didn't see it to after they were done.also a broken rib won't lose the ac a guy is flying one missing the first two ribs on the right wing has been since last fall
ok found the thread wasn't hard to do 7 to 2 none but the other guy thought it was problem from power and sig told you it wasn't a load bearing part they arn't you would have to go 300 to 400 mph before you would have a problem with the rib collapsing from pressure saito 180's rock on this plane
