RCU Forums - View Single Post - Wheel problem
Old 11-11-2004 | 11:40 AM
aliens8mycow's Avatar
aliens8mycow
Default RE: Wheel problem
While we're at it, make sure you have some acetone (or fingernail polish remover) handy. The ca glue will stick your fingers together if you get it on you. The acetone also makes it easy to clean up your work if some of the glue runs down the tire or rim. Again - avoid using too much of the glue.
