RE: Mt2 diff fluid
They are not completly sealed to hold light fluids. If you use really thick grease or the "Diff Locker" fluid that stuff is so thick it will not come out. The outdrives also fill in the holes are the sides and help seal things up. Run the thich fluid and you will be good-to-go.
