RE: Great Planes Cap 232 Kit
Looks good. Look for the thread "GP Cap is almost there" for some recent posts amd pics of some recently built planes. Mine has OS 50 sx power, which is pretty adequate with 10% and a 13x4 prop. I modded mine only slightly - moved rudder servo to l/h side (pull/pull strikes me as a better option tho), plastic u/c bolts and new blind nuts ( do this if you do nothing else - has saved me on 3 rough landings and means u dont need the beefed up u/c mounting.) I also cut lightening holes in the ele and rudder tip pieces. I stuck with std aileron set up - my parts were fine. Plane rolls very fast even with such thin ailerons! Mine also came out quite light. Watch out for windly days as the plane is light and bulky and gets tossed about easily
