Learning to fly without an instructor.
Troy,
We understand your dilemma. If at all possible try using a simulator designed with R/C planes in mind. FMS or Real Flight and others are worth while investments if you can afford it. The idea is to use your TX as the interface or buy the one that comes with Real Flight.
There is no doubt using a simulator is the next best thing. Save yourself the agony of crashing your trainer. You will feel more comfortable after some simulation time.
If you do go this route take into consideration the type of computer you have and the necessary requirements that it takes to run these simulation programs. All of this information is located on the manufacturer's website for Real Flight. Good luck!
