RE: Help with Royal engine
Never used the oven so I don’t know. However the heat gun might work and it doesn’t cost anything to try. Set the front housing on wooden blocks before heating so the bearing can be tapped with a wooden dowel or punch when warm. The aluminum grows considerably faster than steel and it should not take much heat. Don’t get the bearing crooked in the case.
