RCU Forums - View Single Post - SIG Kavalier Build
Old 11-13-2004 | 11:59 AM
ZeppelinIII
Default RE: SIG Kavalier Build
Pilgrim,
My ailerons also end short of the wingtip...even with the second to last rib. One note is to make sure you seal the hinge lines, because mine had some flutter when i first flew it (ailerons were sealed, but rudder and elevator were not)...i've since changed props and sealed the other surfaces and it is no longer a problem. I only have one servo on the ailerons, but it is beefer than a standard servo.
Thanks for you compliment on the covering...the wing is monokote, the fuse is actually glassed and painted (as an experiment)...liked how it came out and learned a lot in the process...
I have a few more build pictures, and can always take more of the finished plane if you have any questions...i love this plane :-)
