Starjet / RAM500
Hi Kelly,
While doing a bearing change after a very small number of runs, I saw that the turbine wheel had been bored off centre. The LE face of the turbine wheel was ground away to try to bring it into balance thereby comprimising its efficiency, balance and safety. I've decided to replace it with a wheel supplied by Wren. After that issue is sorted out I'll try to figure out my flaming out problem. Maybe a new ECU....
