ORIGINAL: Foamaholic
AstroFlight 109 for large lipos. There are more expensive chargers out there but the 109 does most everything.......................
I was going to order an Astroflight 109, but read that you cannot feed it from an automotive battery. A special wall power unit is supposed to be needed. Is that right?
If so, the Astro 109 appears pretty useless at the field if no AC main power is available.
Is the info about the necessity of a special power unit correct?
Joje
