RE: BTE Venture 60 build has Commenced!
I worked on the Venture 60 alot today but you can barely tell. I finished up the mounts for the aft mounted servos. I fuel proofed the engine compartment and fuel tank bay. Mounted the tailwheel. Set in the fuselage top and sanded it flush.
Tomorrow and Tuesday I need to create the wing servo mounts. Glue in the two remaining wing balsa covering sections. Put the fiberglass cloth on the wing joint. Start the tail feathers!
