RCU Forums - View Single Post - Building a Dynaflite Super Decathlon
Old 11-15-2004 | 09:57 AM
cruzmissile's Avatar
cruzmissile
Default RE: Building a Dynaflite Super Decathlon
I did some work last night and I completed the entire horizontal stabilizer. Getting the T-pins in the exact place to create the laminated 1/16 X 3/8 strips was not too bad. did however have my fingers glued to it several times while I was holding it down. The construction of the Horizontal stabilizer is straight forward and pretty easy. Before I glued the trailing edge of the stabilizer and the leading edge of the elevator, I pre cut slots for the dubro hinges I'm using. It's easier to work with than handling the whole stabilizer itself.
ID:	193106   Click image for larger version
ID:	193107   Click image for larger version
ID:	193108   Click image for larger version
