RCU Forums - View Single Post - I'm getting interference!
Old 11-15-2004 | 01:43 PM
Chris Moon's Avatar
Chris Moon
My Feedback: (8)
Default RE: I'm getting interference!
What kind of radio? What range do you get when you range check with the engine off? And then range check with the engine on. Also, try running the battery right into the RX to see if the switch is bad. You might un plug one servo at a time to see if one is causing the problem. Move the RX and antenns placement to see if there if is picking up noise from some close by wiring. Lots of possibilities.
