RE: I'm getting interference!
I had the same problem with my F90 when I installed a 1.80. Its your linkage even if the push rod comes close enough to the engine case it will cause interference.
I used ny-rod to fix the problem, check the engine and carb assembly very carefully you will find the problem there.
