RCU Forums - View Single Post - Side thrust
Thread: Side thrust
Old 08-19-2002 | 10:46 PM
SRA Foam Flyer
Default Side thrust
Also, in a tractor situation, the thrust rolls over the planes surfaces in a biased fashion and the plane reacts as if control surfaces are being actuated. Some muanfacturers have you offset the vert stab to compensate, some have you install the firewall offset and some just have you tweek the motor mount with shims.
