RCU Forums - View Single Post - Problem with needle valve
Old 11-16-2004 | 12:00 AM
DarZeelon's Avatar
DarZeelon
Default RE: Problem with needle valve
Barkai,
Try putting a piece of silicone fuel line on the outside of the needle housing, so when the needle is at its running position (about 2-2.5 mm open), it will just butt up against it. It should hold in place then.
Put it on dry, not wet with oil.
