RCU Forums - View Single Post - down/right thrust??
Old 11-16-2004 | 01:31 AM
feihu-RCU
Default RE: down/right thrust??
Try to estimate where the CG would be on the side view of the airplane, considering the weight of the locations of the battery, landing gear, wing, inverted engine or not, etc. Where you locate the engine on the nose will determine the amount of downthrust/upthrust you will need. You will need no downthrust or upthrust if you locate the engine so that the horizontal thrust line passes thru or slightly above the CG. If you locate the engine below the CG, then you should add downthrust until the thrustline passes thru or slightly above the CG. If you locate the engine above the CG, then you may need upthrust to have the thrust line pass thru the CG; however, because of other factors that are speed related, you can tolerate a larger displacement of the thrust line above the CG.
You are estimating where the CG will be, but you will never know until the airplane is completed, so a minor adjust might be required after flight testing.
feihu
I would not use any sidethrust on an aerobatic plane.
I have successfully designed and flown many planes in the past, and these are my opinions/suggestions.
